Keil uLink 2
Keil uLink 2
2,402 次查看
juliancox
Contributor V
Does anyone know if the KEIL ULINK 2 probe can be used with CodeWarrior or (more useful to me) the USBDM programming utility? I know that the pod will support Single Wire Debug.
标记 (2)
2,219 次查看
juliancox
Contributor V
This is an option for ARM (which is why I have a ULINK 2) but Keil does not support S08 devices.
2,219 次查看
ZhangJennie
Hi Julian,
CodeWarrior and USBDM doesn't support KEIL ULINK 2 .
If you use ULINK2, please consider KEIL MDK.
Please
Jennie Zhang
2,220 次查看
juliancox
Contributor V
