Is there a stdargs.h header file for CW 10.2?
1,187 次查看
samsaprunoff
Contributor V
Good day all,
I was curious if there is a "stdargs.h" header file for CW 10.2?  I ask, as I have some legacy could that I would like to port and it uses stdarg.h within some of its routines.  I could go through it and re-write it, but was hoping that there was a stdargs.h that I could use.
Thanks in advance!
Cheers,
Sam
标记 (3)
1,084 次查看
DerekLau
There are stdarg.h (not stdargs.h) files under the subfolders of \Freescale\CW MCU v10.2\MCU.
1,085 次查看
DerekLau
1,084 次查看
samsaprunoff
Contributor V
Good day Derek,
Thanks for your response!  Indeed, I made a mistake in the header file name for some reason I added the "plural" version :smileyhappy:
Cheers,
Sam
