Installation Problem
3,187 次查看
foo223
I'm trying to install Codewarrior HCS12(X) v4.7 and it seems to make it all the way to the end, then says, "Rolling Back Action" for no apparent reason.  Then it simply says that the process was interrupted without supplying any other information.
Any help would be greatly appreciated.
标记 (1)
2,643 次查看
foo222
problem solved by deselecting emulator installation on install.  not exactly sure why that worked, but thanks for everyone's help.
4 回复数
2,644 次查看
kef
Specialist I
64bits windows? If yes, then check out this thread
 https://community.freescale.com/thread/57404
2,644 次查看
foo222
Thanks for your quick reply, but unfortunalty it`s not a 64 bit PC.  I'm using XP.
2,644 次查看
CrasyCat
Specialist III
Hello
Make sure you disconnect all USB devices from your computer before starting installation.
Issue may arise if you have a debugging cable from any provider hooked up to one of your USB port when attempting to install.
CrasyCat
2,644 次查看
foo222
