How to see the speed clock (Bus frequency) configuration in debug perspective for eclipse 10.2?
orlandozapata
I am using a MCU51QE128, and  I want know how to see the clock speed that was configurate in my MCU using codewarrior development studio - eclipse 10.2 in debug perspective, When I worked in codewarrior 6.3 I could see this speed clock in the command window when this was configured step by step . Somebody know How find this window or what should I do to see the speed clock in my proyects using eclipse 10.2?
My Code:
void Config_Reloj(void){
ICSC1=4;                  //ajusta el reloj interno
ICSC2=0;                  //frecuencia de bus de 26´748.225hz
ICSSC=0X70;
ICSTRM=0X40;
SOPT1=0X12;               //desactiva el reset
Thanks for your help and apologize for my english
ZhangJennie
Please see attached pictures of how to enable logging.
orlandozapata
Hi ZhangJennie,
I could see this bus frequency configuration. This seems the initial bus frequency configuration of the PnE U-MultiLink. I would like to see the MCU frequency  (MCU clock speed) that my code sets step by step to reaffirm that is  near to 26.7 Mhz in the function "void Config_Reloj(void)". I´m using the code that I posted initially. Where can I see that in debug perspective??
Thanks for you time.
