How to see the speed clock (Bus frequency) configuration in debug perspective for eclipse 10.2?
1,332 次查看
orlandozapata
I am using a MCU51QE128, and  I want know how to see the clock speed that was configurate in my MCU using codewarrior development studio - eclipse 10.2 in debug perspective, When I worked in codewarrior 6.3 I could see this speed clock in the command window when this was configured step by step . Somebody know How find this window or what should I do to see the speed clock in my proyects using eclipse 10.2?
My Code:
void Config_Reloj(void){
ICSC1=4;                  //ajusta el reloj interno
ICSC2=0;                  //frecuencia de bus de 26´748.225hz
ICSSC=0X70;
ICSTRM=0X40;
SOPT1=0X12;               //desactiva el reset
Thanks for your help and apologize for my english
标记 (3)
1,164 次查看
ZhangJennie
Please see attached pictures of how to enable logging.
1,164 次查看
orlandozapata
Hi ZhangJennie,
I could see this bus frequency configuration. This seems the initial bus frequency configuration of the PnE U-MultiLink. I would like to see the MCU frequency  (MCU clock speed) that my code sets step by step to reaffirm that is  near to 26.7 Mhz in the function "void Config_Reloj(void)". I´m using the code that I posted initially. Where can I see that in debug perspective??
Thanks for you time.
