?How to minimize program memory size?
pengliang
I am using CW V10.3 for Kinetis L KL25Z development. Also, I use PE for generating the hardware initialization code.
The program size is quite large like 4k Byte. even I just toggle an LED. why is that large? because of PE generated code? How can I minimize the program memory size?
Thank you
carxander
Hello!
Recently i read this post from Erich, I hope this help:
Optimizing the Kinetis gcc Startup | MCU on Eclipse
