How to get stack usage analysis?
5,746件の閲覧回数
達裕百鳥
I use the following:
CW for MCU V10.7
Freescale Assembler for Embedded ARM family.
Version 2.0 build 59 (build 59)
Freescale C/C++ for Embedded ARM.
Version 5.1 build 59 (build 59)
Freescale Linker for Embedded ARM.
Version 3.0 build 59 (build 59)
タグ(1)
5,305件の閲覧回数
BlackNight
Your screenshots indicate you are using the depreciated/legacy Metrowerks ARM compiler. That option only exists for the GNU gcc compiler:
I hope this helps,
Erich
6 返答(返信)
5,305件の閲覧回数
BlackNight
5,305件の閲覧回数
達裕百鳥
Thank you very much for your reply.
I tried to build a program with "-fstack-usage" compiler option.
However, an "Unknown option" error has occurred.
Did I make the wrong setting?
Tatsuhiro
5,306件の閲覧回数
BlackNight
I hope this helps,
Erich
5,305件の閲覧回数
達裕百鳥
I appreciate your response.
Do you know if this ARM compiler does not have a stack usage analysis option?
Tatsuhiro
5,305件の閲覧回数
BlackNight
It does not have such an option.
5,305件の閲覧回数
達裕百鳥
Thank you Erich. Your explanation was easy to understand.
