How to get stack usage analysis?
5,758 次查看
達裕百鳥
I use the following:
CW for MCU V10.7
Freescale Assembler for Embedded ARM family.
Version 2.0 build 59 (build 59)
Freescale C/C++ for Embedded ARM.
Version 5.1 build 59 (build 59)
Freescale Linker for Embedded ARM.
Version 3.0 build 59 (build 59)
标记 (1)
5,317 次查看
BlackNight
Your screenshots indicate you are using the depreciated/legacy Metrowerks ARM compiler. That option only exists for the GNU gcc compiler:
I hope this helps,
Erich
6 回复数
5,317 次查看
BlackNight
5,317 次查看
達裕百鳥
Thank you very much for your reply.
I tried to build a program with "-fstack-usage" compiler option.
However, an "Unknown option" error has occurred.
Did I make the wrong setting?
Tatsuhiro
5,318 次查看
BlackNight
I hope this helps,
Erich
5,317 次查看
達裕百鳥
I appreciate your response.
Do you know if this ARM compiler does not have a stack usage analysis option?
Tatsuhiro
5,317 次查看
BlackNight
It does not have such an option.
5,317 次查看
達裕百鳥
Thank you Erich. Your explanation was easy to understand.
