How to change the source file location?
817件の閲覧回数
danielchai
Senior Contributor I
When I create a new source file in a project, it will create a xxx.c under the current folder.
How could I set the CW10.4 so that when I create the source file, it will create it in specific folder?
Thanks.
729件の閲覧回数
BlackNight
It will use the folder you right click on as the default.
If you want to use a specific folder, either type the path or use the browse folder:
