How do I perform boundary scan using CodeWarrior TAP?
4,335 次查看
evanlim
How do I perform boundary scan using CodeWarrior TAP for MPC5200?
Does it have a fix programming code for it?
Which codewarrior software should I install in order to perform boundary scan?
Thank you.
Evan
4,105 次查看
TICS_Fiona
Hello Evan
We do not have recommendation for using boundary scan JTAG mode for final testing of hardware.
You can find the BSDL file from:
http://www.bsdl.info/list.htm?m=15
The BSDL file for MPC5200 is on page 4.
For example, please have a look at:
http://www.jtagtest.com/
www.corelis.com
Hope this will help you.
Best Regards
Fiona Kuang
Technical Information & Commercial Support
4,106 次查看
TICS_Fiona
Hello Evan
www.corelis.com
Best Regards
Fiona Kuang
4,104 次查看
evanlim
Hi Fiona,
We have to download another JTAG software to run boundary scan?
Thank you.
Evan
