Hello forum members,   I am using Codewarrior 4.6 build 6...
1,914 次查看
SSK
I am using Codewarrior 4.6 build 6345 with MC9S12A128B. I am trying to use interrupt for SCI0 but while compiling the code , it gives following error(s) -
Error   : C1017: Empty declaration
STT25x.c line 85
Error   : C2801: ';' missing
STT25x.c line 85
Error   : Compile failed
I am also attaching a snap of the error. Your earliest help is highly appreciated.
Thanking you in advance.
标记 (1)
948 次查看
Stephen
Try reordering the function declaration to put the void keyword before the interrupt keyword.
E.g.
void interrupt _SCI0_interrupt(void)
 /* your code goes here :smileyhappy: */
Good luck
Steve
949 次查看
Stephen
E.g.
Good luck
Steve
