FLEXLM Installation Problems
3,752 次查看
TSS
I am trying to install the FlexLM on a windows XP SP2 machine. I downloaded the installers from the freescale website. I am getting a "Component Transfer Error". But I am able to install the same on different machines with the same OS.
Thanks for the help,
标记 (1)
2,583 次查看
CrasyCat
Specialist III
Hello
I did browse around in google and found an interesting article from Microsoft Help & Support.
Look at following URL:
It looks like you need to install Windows Installer 3.1 (v2)
CrasyCat
2,583 次查看
TSS
Windows Installer V 3.01.4000.1823
2,584 次查看
CrasyCat
Specialist III
Hello
CrasyCat
2,583 次查看
CrasyCat
Specialist III
Hello
Which version of Windows Installer are you running?
To retrieve that information:
  - From et Start menu select Run
  - Enter the command msiexec and press OK
A window will be opened showing the Windows Installer version number.
CrasyCat
