Errors and warnings not showing up in Problems view
1,451 次查看
chicagomike
I'm using the evaluation version of CodeWarrior v10.4 on a Coldfire MCF51JF128 project. When I build my project, I can clearly see compiler errors and warnings in the Console view of the C/C++ perspective, but the Problems view always remains empty. Why?
Mike
1,216 次查看
BlackNight
Hi Mike,
in order for the problems view to show the messages, it needs to 'understand' what is written to the console view.
For this, make sure you have parsable messages produced (project build tools options):
then make sure that the error parsers of the problems view are selected:
This should be set up by default, but maybe something is missing on your side.
I hope this helps.
Erich
1,217 次查看
BlackNight
Hi Mike,
I hope this helps.
Erich
1,216 次查看
chicagomike
That did it! Not sure why it wasn't on by default.
Thanks, Erich.
