Disable interrupt during step CWHC08 V5
1,894 次查看
calou
I use CW for HC08 and the evaluation freescale card with 9s08AW60. Is it possible in the debugger to disable interrupt during step?
Thank you very much
标记 (1)
992 次查看
Nabla69
Contributor V
Yes it is,
Simply double click on the "I" bit in the CCR Register and it will mask all maskable interrupt sources.
Cheers,
Alvin.
993 次查看
Nabla69
Contributor V
Yes it is,
Cheers,
Alvin.
