Control PWM using CAN message with FRDM-KE06 board
2,350件の閲覧回数
maidana
I'm starting the develop projects using microcontroller freescale. I'm using the frdm-ke06z and I need make a project the control the PWM signal through the CAN messenger.
Somebody have some tutorial to help me?
best regards
Wellington
タグ(2)
2,084件の閲覧回数
ZhangJennie
I don't know there is a document regarding control the PWM signal through the CAN messenger.
but you can refer PWM and CAN demo code to make your own code from CW install:
C:\Freescale\CW MCU v10.6.4\MCU\CodeWarrior_Examples\Kinetis_Examples\KE\src\projects\KE06
Can this help you?
Jennie Zhang
2,084件の閲覧回数
maidana
Hi Jennie Zhang,
I go follow this example. Thanks for answer.
Wellington
2,085件の閲覧回数
ZhangJennie
Can this help you?
Jennie Zhang
