CodeWarrior and TestTool.exe
2,169 次查看
xyz
I am trying to write a program to HCS08(GT60) using Code Warrior Special Edition through RS232 port since my MCU already has an Embedded BootLoader. Do i actually need TestTool.exe to burn my program into the MCU? If so, where can i find it? My Code Warrior Special Edition doesn't have that file....Pls help.
标记 (1)
1,527 次查看
peg
Senior Contributor IV
Hi xyz,
You need to select "HCS08 Serial Monitor" as your connection.
Normally done as the second step in the new project wizard.
1,528 次查看
peg
Hi xyz,
