CodeWarrior 10.4 Evaluation Installation Issues
1,419 次查看
thoomanwang
Contributor V
I downloaded the CodeWarrior 10.4 Evaluation , also applied for a license, but after I installed license management interface appears in the following interface
Try a bit and found a 64K code limit , how should I do to trial Professional Edition features it ?
标记 (2)
1,230 次查看
ZhangJennie
please check your license install path. it must be under path {CW10 install}\MCU
1,231 次查看
ZhangJennie
1,230 次查看
thoomanwang
Contributor V
THanks
