Can Cyclone FX be used as a debugger in CodeWarrior to debug K60FN1M0?
1,577 次查看
smecolive
I found Cyclone MAX in Code Warrior to use as a debugger, not Cyclone FX.Has anyone tried using Cyclone FX as a debugger?Thanks
1,557 次查看
ZhangJennie
Hi smecolive,
According to P&E,
The Cyclone FX is able to debug K60FN1M0 target within CW11 when using the PE Micro plug-in. The PEMicro driver should be included when installing CW11.
Hope this helps,
Jun Zhang
1,558 次查看
ZhangJennie
Hi smecolive,
According to P&E,
Hope this helps,
Jun Zhang
