CRC generation in CW 4.02 IDE
1,759件の閲覧回数
dipkamat
Hi all
I am using CW 4.02 to build a project for DSP56F805 MCU.I would like to know how to generate the CRC of the BIN file/elf file?Is there any option in the IDE for the same?
Are ther any tools available for CRC generation taking elf/BIN file as input?
1,629件の閲覧回数
TICS_Fiona
Hello Dip
The CRC generation feature was introduced in CW8.0 linker, the earlier version does not support this feature.
If you need the CRC value of your application code, please make it by yourself by user code in your application.
In addition, When programming with our tool (CodeWarrior for flash_over_jtag), the tool does verify the programming,  user need not worry about any error in programming.  And in the S-record file generated by CodeWarrior, each line contains the CRC value for the data in this line.
Best Regards
Fiona Kuang
TIC - Technical Information Center
Note: If this post answers your question, please click the Mark Correct button. Thank you!
1,630件の閲覧回数
TICS_Fiona
Hello Dip
Best Regards
Fiona Kuang
