Adding a missing MCU in LIN Node Configuration Tool GUI editor
1,916件の閲覧回数
didierroncin
What is the (is there a ?!) procedure allowing to add a missing MCU (or remove unwanted ones) in the "LIN Node Configuration Tool" GUI editor (ncftool_1.4.8) for Code Warrior (10.7)
We are experimenting with MC9S12ZVLA128 MCU which is missing fom the list of available MCU.
We know we can manually edit the generated config file, but just in case to avoid confusion...
Thanks in advance for your support.
Did.
1,638件の閲覧回数
ZhangJennie
All the LIN stack supported devices  are listed in LIN_User_Manual.pdf "2.2 Supported Derivatives", under your LIN stack install. If your device is not on the list, we can't add it manually.
Jennie Zhang
