10.5 to 10.6 -> behavior changed, s-file changed
891 次查看
andreasvogt
Hi to everyone,
I compiled the same project (every project file and source file is identically) on CW10.5 and CW10.6. The result is that I have two different s-files and the code behaves differently. In the new 10.6 MAP file the size of different locations changed.
Made someone the same experience? What changed between 10.5 and 10.6?
821 次查看
trytohelp
Hi Andreas,
The build tool chain was updated so depending of your project, the generated code could be different and so the Srecord file and project mapping too.
Pascal
NXP Technical Support
