Relocate Code (configuration linker files) - CW10.6 - Kinetis
The 3 simple  code are relocate code to rom、special ram and external ram.
They are create on CW10.6, K60dn512  chip .
It is  same with  relocate data .
添付
コメント
Thank you for posting this
Please give sample project bellow configuration
Build and Debug Configuration
          1. Code(.text) in Flash and Data(.data,.bss, stack, heap etc) in DDR2
          2. Both Code and Data in DDR2.
HW: TWR-K70F120M
SW: CW10.6 ARM GCC
Hello.
I need question.
How to use "  __relocate_code__ "  in KSDK?
for gcc gnu
Hello Prof,
Please check this DOC at here : Relocating Code and Data Using the KDS GCC Linker File for Kinetis
Hope it can help you !
Alice
評価なし
バージョン履歴
最終更新日:
‎01-29-2015 07:21 PM
更新者:
