tja1145 selective can wake up
2,666件の閲覧回数
jackjack
i am trying to use selective can wake up of tja1145, I ran into a problem。
1 the computer send a can message to tja1145 with matched ID,tja1145 can wake up.
2 the computer send a can message to tja1145  with a unmatched ID first ,then send a matched ID,tja1145 can not wake up.
it is because when the computer send a can message to tja1145  with a unmatched ID, tja1145 will not respond to this message, and the result is that it will continue to send the can message with unmatched ID, even if i want to send a can messaage with a matched ID, it can not be send because the first can message is not sent successfully.
it seems that it is about the ACK bit in can message.
even if it is not a can message with a matched ID,can tja1145 respond to that message so the next can message can be sent? how?
タグ(2)
3 返答(返信)
2,201件の閲覧回数
ZhangJennie
HI,
What's your MCU part number?
What version of CW do you work with?
Jennie Zhang
2,201件の閲覧回数
jackjack
MCU:MPC5744P
S32Design studio2017
2,201件の閲覧回数
ZhangJennie
Hi Jack.
I don't support this target.
I heard PPC5 team was very busy recently, I am not sure they have time to check community these days.
If your question is very urgent, I suggest you submit a case to NXP technical support team
https://community.nxp.com/docs/DOC-329745
Jennie Zhang
