tbdml_gdi12.dll not loaded
3,303件の閲覧回数
yunjieli
Driver DLL CWS12v5.1\prog\gdi\tbdml_gdi12.dll or one of its components not found or loaded. System Error 126 when I debug my MC9S12XDP512 in Windows 10. Anyone has idea what this problem is and how to solve it? Thanks.
2,714件の閲覧回数
trytohelp
Hi Li,
There are some restrictions due to driver limitations for 64 bit on new Windows versions.
You will see more details under the txt files: \CWS12v5.1\Release_Notes\HC12
    Notes_CW_HC12_64bit.txt
    Notes_CW_HC12_Vista.txt
Extract of  Notes_CW_HC12_64bit.txt:
Known problems:
(1) The following connections are not working with 64 bits Windows:
        - USB-ML-12-Rev A
        - USB-ML-12-Rev B
        - Softec - inDart-HCS12
        - TBDML
Pascal
NXP Technical Support
2,715件の閲覧回数
trytohelp
Hi Li,
Known problems:
        - USB-ML-12-Rev A
        - USB-ML-12-Rev B
        - TBDML
Pascal
