target task greyed out
hawk
I am getting the error "Error setting debug context for run configuration Active Debug Context".
Some reading and I came "target configuration", which is greyed out. So I can't check it or change it.
Can anyone help me with the above error. I am using USB Multilink universal to (attempt) to program a MC9SO8AW32.
I have never seen BKGD go low, will check clock now. Ok, found one problem, needed b+ on another trace. Processor running.
But now I have these two new errors: According to the forum, a-lot of people do. Followed the suggestions in those posts and those pins seem ok. BKGD, VDD, Gnd, and reset.
Much Thanks,
David
Rick_Li
Hi David,
Please accept my apology for the time delayed to get back to you on this issue, I was heavily backlogged!
regarding this problem, if it still there, then, could you mind upload an screen-shot to here for further investigating?
hawk44
Thank your for your kindness.
Problem resolved, erased, re-flashed.
Thank your for at least replying, I was under pressure to get the job done by xx time and I am new to CodeWarrior,
It was about to drive me nuts, seemed like the simplest things didn't work.
But we got it done, a day ahead of time. :smileyhappy:
Thanks again for your reply. Have a great day and weekend
David
