problem with programming S08SH8
3,170件の閲覧回数
juliancox
Using CW11 and Multilink Universal I can debug my S08SH8 successfully, but when I try to flash program it i get the error
Also when using the cyclone i get the Error Code $00000007 Error: Cannot enter debug mode.
I am not , and never have, used a MC9S08QE16
3,160件の閲覧回数
vicentegomez
From your picture
Are you are trying to program the SH or the QE device?
Please check that you only have one project open in code warrior also please check that the connection is for the SH device
I hope this will help you
Vicente
3,089件の閲覧回数
juliancox
I know this is a very old post, but I am just tidying up. However:
1. When I say that I am not, and have never used a QE16 - that is a clue to the fact that I am NOT trying to program a QE16
2. I have only one open project, but since none of my (closed) projects use  a QE16, whether I have all or only one project open should not matter.
3,160件の閲覧回数
vicentegomez
From your picture
Vicente
