1046 NOTICE UDIMM M4DS-AGS1QC0J-BE82
2,546 次查看
atrqua
A notice "NOTICE UDIMM M4DS-AGS1QC0J-BE82"  prints every seconds when I power on LS1046.
And ofcourse , LS1046 could not boot up anymore.
I need help, Thanks
2 回复数
2,537 次查看
yipingwang
Please refer to packages/firmware/atf/plat/nxp/soc-ls1046/ls1046ardb/ddr_init.c in LSDK, did you also use reading DDR controller configuration parameters form SPD?
Please check whether "define NXP_SPD_EEPROM0 0x51" defined in atf/plat/nxp/soc-ls1046/ls1046ardb/platform_def.h is suitable for your custom board.
2,534 次查看
atrqua
Very Thanks for ur reply:
My LS1046  connects to a RF board named Agave.
And the problem is due to the broken Agave.
But I still want to know why this NOTICE comes out when I plug in a broken Agave.
This Notice means a DIMM problem ……
