multiple pairs of the same variable in debug
10,490件の閲覧回数
legnanimassimo
there is a problem that I cannot solve:
Using Codewarrior 11.1, every time I re-compile my software, if I leave the view related to Global Variables active, when the compilation ends, the variables previously inserted (to check their value), are repeated at each compilation and after a few times it is no longer possible to display their value ... they must be deleted and entered again.
A solution would be to change the active display from 'Variables' to any other one (Breakpoint .. etc.) before starting the compilation.
I seem to have understood that this is a known Eclipse problem but I have not been able to find the solution.
This problem is very annoying when debugging the software.
Thank you
10,187件の閲覧回数
ZhangJennie
compiling process can't invoke "variable" window.
Once  open a "variable" window in debugger, this window remains in debugger. We can still see it next time during debugging.
12 返答(返信)
10,479件の閲覧回数
ZhangJennie
HI
Could you please check if you create a new project under a new workspace. How does it work?
We need to identify if the problem is associated with a certain project or workspace.
Jun Zhang
10,471件の閲覧回数
legnanimassimo
Hi Jun, hanks for the quick attention.
The problem appears in any context: both an existing project and a new project ...
10,462件の閲覧回数
ZhangJennie
did you try new workspace? or remove current workspace .metadata folder?
How about reinstall CW in another directory?
10,450件の閲覧回数
legnanimassimo
Hi ZhangJennie
unfortunately I don't have time to try by reinstalling everything. I tried on another pc where I transferred the entire Workspaces folder with the metadata subfolder of the main pc, in order to transfer all the works and customizations. Obviously, on this too I get the same problem. Perhaps during the Christmas holidays I will be able to find some useful clues.
Thank you
10,440件の閲覧回数
ZhangJennie
reinstall is my second suggestion.
The first suggestion "did you try new workspace? or remove current workspace .metadata folder?" doesn't take time.
This is used to identify if the problem is caused by project or workspace setting.
Jun Zhang
10,416件の閲覧回数
legnanimassimo
As soon as I have some time, I'll try to do the tests you recommend and I'll let you know.
Thank you
10,264件の閲覧回数
legnanimassimo
Hello everyone and happy new year,
unfortunately I was unable to do the tests that Jun Zhang had suggested to me and for this reason I ask if it was possible to automatically activate a perspective other than 'Variables' during the compilation, so I would bypass the problem.
Thank you
10,239件の閲覧回数
ZhangJennie
Could you please specify what is "automatically activate a perspective other than 'Variables' during the compilation,"?
10,235件の閲覧回数
legnanimassimo
I mean that, since the problem occurs only if I restart the debug (F11) with consequent compilation of the software leaving the Variables window active, I was wondering if it was possible to make sure that by starting this procedure (F11) another window is automatically activated display (eg Breakpoint)
10,197件の閲覧回数
ZhangJennie
For example, to open breakpoint window after click debug button, please follow below screenshot
10,190件の閲覧回数
legnanimassimo
in fact that's what I usually do, before re-compiling .. the problem is: 'I don't always remember doing this'.
For this reason I was wondering if it was possible to set a window other than 'variables' that would be automatically called up by the compilation procedure.
Thank you
10,187件の閲覧回数
ZhangJennie
