how to flash HCS08JM16 demo board?
1,935 次查看
pradeepkumar
I tried to flash the demo board using Code warrior 10.5 but showing that "No device avaible" 9938_9938.jpgdebug.JPG.jpg
I successfully flashed the device using code warrior 6.3 classic IDE
1,774 次查看
Jorge_Gonzalez
Hello Pradeep:
The "No Device Available" indicates that your tool is not recognized. What programming tool are you using?
This is often caused by missing or corrupted drivers.
The next thread of our colleague Erich Styger will show you all about P&E drivers. Please give it a check and update your drivers:
Fixing the USB Drivers | MCU on Eclipse
Hope this helps!
/Jorge Gonzalez
1,775 次查看
Jorge_Gonzalez
Hello Pradeep:
Hope this helps!
/Jorge Gonzalez
1,774 次查看
pradeepkumar
Hello Jorge Gonzalez,
The article which you directed me to follow had solved my issue thank for your support
Pradeep Kumar
1,774 次查看
Jorge_Gonzalez
You are welcome Pradeep!! I am glad it worked.
Jorge Gonzalez
