how can I generate a .wsd files
2,764 次查看
niklasroth
I wonder how I can generate a .wsd files that includes the mqx project, bsp and the psp, like its done in the examples.
Does any one know where I can read about it or even have a short easy answer?
Thx and cheers
2,613 次查看
Carlos_Mendoza
Hi Niklas,
I think that the following post created by our colleague Erich Styger might be helpful for you, it explains how to create a working set:
Eclipse Working Sets Explained | MCU on Eclipse
Hope it helps!
Carlos Mendoza
Technical Support Engineer
2,614 次查看
Carlos_Mendoza
Hi Niklas,
Hope it helps!
Carlos Mendoza
2,613 次查看
niklasroth
Thank you Carlos!!
Yes this helped =D
