adv7482 driver:Failed to get default crop rectangle with VIDIOC_G_SELECTION: Invalid argument
Ohm86
I am using adv7482 driver on iMx8mPlus board.
Please anyone can help me to solve below  issue :
Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Invalid argument
I have attached the logs file please look into this and help me to get rid of this issues.
Thanks in advance.
AldoG
Could you share the BSP version that you are using for your test?
Also, are you testing on the EVK?
Best regards/Saludos,
Aldo.
Ohm86
Hello AldoG,
Thanks for replying.
I am using below bsp version
mickledore imx-6.1.55
and also i have imx8Mplus development board.
gstreamer version is 1.22
Ohm86
Hello AldoG,
Any Update?? Because  I am still not able to resolve the issue.
I have same issue as mentioned below link:
https://community.nxp.com/t5/i-MX-Processors/custom-image-sensor-driver/m-p/1860270
