Code warrior enquiry
Kernelhacker
We intend to debug and validate boards based on T-series QorIQ processors.
Please confirm that following parts will be sufficient:
1. CWH-CTP-BASE-HE (basic unit)
with
2. CWH-CTP-COP-YE (removable probe tip)
We want to use the QCVS (ddr validation suite). Do we need to purchase license for that separately? Or it is bundled in with the above hardware.
Please also attach the codewarrior software installation package
yipingwang
1. Your purchased CodeWarrior TAP and the probe tip are correct.
2. You need to purchase Specialist Level Suite CodeWarrior license from https://www.nxp.com/design/design-center/software/development-software/codewarrior-development-tools...
3. I uploaded CodeWarrior and QCVS(DDR) tool in the following link.
https://support.nxp.com/s/case/5002p00002zooySAAQ/community-code-warrior-enquiry?language=en_US
Please install CodeWarrior for PA 10.5.1 first, then open CodeWarrior IDE and install QCVS for PA 4.5 from Help->Install New Software->Add->Archive.
Kernelhacker
NXP team,
Is it possible to run codewarrior on linux along with qcvs suite?
Kernelhacker
Thank you so much.
yipingwang
