When CDROM is not present, How Can I install code warrior?
1,256 次查看
venkatasaisreeg
Installation procedure
- Insert the CDROM into your drive, and make sure it is mounted.
- Navigate to the drive's mount location via a terminal window, or via a File Viewer window.
Please someone explain how I should proceed if I dont have a CDROM with my laptop.
1,174 次查看
Hello VENKATA SAI SREE GUTTULA ,
You can simple download the installer , and install it , the download site is :
CodeWarrior Embedded Software Development Tools|NXP
Please choose the CW version you want to use .
Hope it helps
Alice Yang
