To measure Execution Time with Codewarrior 10.2
4,329 次查看
alessandrodioni
I have a problem to mesure the execution time with CodeWarrior 10.2 in debug phase.
Is there a tool to measure the time between two breakpoint, like "StopWatch" in MPlab.
I want to know the time of instructions group.
Can you help me?
Ale
3,825 次查看
alessandrodioni
I use the MC9S08AC128.
Thank you for the information.
3,825 次查看
ZhangJennie
what chip do you work with? i will see if i can provide you more information per chip
3,825 次查看
alessandrodioni
3,825 次查看
ZhangJennie
you can use Profiling and Analysis feature to measure the excution time.
see document Profiling and Analysis Users Guide.pdf under CW10 install
