Remove project path from glo file
2,095 次查看
michthom
i would like to know how to generate a glo file with no project path line.
The purpose is to get the exact same binary file wherever I compile it.
Thank in advance,
Michel Thomas
4 回复数
2,053 次查看
ZhangJennie
hi,
if you use CW for HCS12(x), to remove path from s0 record, please follow below steps in project setting.
can this help you? if not, please port your question here. thanks.
Jennie Zhang
2,053 次查看
michthom
Hi Jennie,
thank you for the fast reply.
This answers the question.
Michel
2,053 次查看
ZhangJennie
you are welcome.
If this post answers your question, please click the Correct Answer button. Thank you.
Jennie Zhang
2,053 次查看
jorge_a_vazquez
Hi Michel
Could you tell us what CodeWarrior version and MCU are you using?
Jorge Alcala
