Program is not stopping at break point in CodeWarrior 5.1
ponalagappan
I am using licensed version of Codewarrior 5.1. In IDE, i am able to set/disable break points. But while debugging, the program execution is not stopping in break points. i doubt on 2 things.
1. Whether any settings is wrong    (or)
2. license update procedure is wrong.
How to check IDE settings are correct to fix this issue
Alagappan
ZhangJennie
This should not be a license issue.
One possible reason is related with optimization. please upload your project here thus we can check the problem directly.
Thanks.
Jennie Zhang
