Program is not stopping at break point in CodeWarrior 5.1
1,122 次查看
ponalagappan
I am using licensed version of Codewarrior 5.1. In IDE, i am able to set/disable break points. But while debugging, the program execution is not stopping in break points. i doubt on 2 things.
1. Whether any settings is wrong    (or)
2. license update procedure is wrong.
How to check IDE settings are correct to fix this issue
Alagappan
1,041 次查看
ZhangJennie
This should not be a license issue.
One possible reason is related with optimization. please upload your project here thus we can check the problem directly.
Thanks.
Jennie Zhang
