Problem with MPC5748G programming using ic5000 from iSYSTEM
2,016 次查看
medhedibasly
I'm working with MPC5748G and ic5000 Debugger with WInIDEA.
Sometimes when i try to reprogram my board (custom board) with new application the board get stuck and i can't download the new application. I tried to erase th flash by performing a mass erase operation, WinIDEA says that the mass erase has successfully passed but the flash is not erased.
Any explanation or a way to explore more this issue would be appreciated.
best regards,
Hedi.
1,830 次查看
ZhangJennie
Hi Hedi
ic5000 Debugger and WInIDEA are both iSYSTEM product. I would suggest you contact iSYSTEM:
iSYSTEM - iSYSTEM - Enabling Safer Embedded Systems
Jennie Zhang
1,830 次查看
medhedibasly
Hi Jennie,
Thank you for your response, i will contact iSYSTEM to discuss the issue with them.
Hedi.
