Problem while installing the codewarrior 8.8
1,725 次查看
maheshwarreddy
Fresh Out Contributor
Now we are using the MPC860 power pc in our custom board. To dbug we are trying to use the code warrior 8.8 but while installing the code warrior we are getting an error as cannot not run an x86 built of this utility on x64 platform. How to solve this . The installing PC will be 64 bit .
Thank you
Maheshwar
标记 (3)
1,626 次查看
Pavel
There is similar message during CodeWarrior 8.8 installation.
Install "Software Patch: CW PA v8.8.6 Windows" after CodeWarrior 8.8 installation. See the following page:
https://nxp.flexnetoperations.com/control/frse/download?agree=Accept&element=6121541
This patch installs driver for CodeWarrior TAP.
Pavel Chubakov
