PMBus Protocol Conversion to Modbus RTU/TCP
3,757 次查看
stephenlacy
Hi Everybody - We love the POL chips, but need to get the data from serial PMBus onto Ethernet (IoT effort) somehow. Converting to serial Modbus 232/485 works (since the drivers exist) or Modbus TCP.  Has anyone figured out a way to do this?
3,413 次查看
ZhangJennie
Hi.
What chip do you work with?
Jennie
3,413 次查看
stephenlacy
Hi Jennie - We're using the BMR 461 4001 (0.6-1.8V 18A/36W). Any help you can give is really appreciated.
Sent from my phone
3,413 次查看
Carlos_Mendoza
Hi Stephen,
I would recommend you to contact this part manufacturer and/or your distributor for details on it's initialization and operation.
Carlos Mendoza
Technical Support Engineer
