PBL RCW
PBL RCW
3,427件の閲覧回数
yoshida08
How can I use CodeWarrior to check if the PBL RCW data from the SD card is loaded?
5 返答(返信)
3,351件の閲覧回数
yoshida08
We could solve the problem that HRESET does not change to High on our design board.
IFC_AVD signal was problem, signal was Low level.
3,352件の閲覧回数
yoshida08
Thank you for your reply.
I'm sorry, I reply late.
I will confirm contents of your reply.
3,393件の閲覧回数
Chavira
Hello yoshida08!
You can Read/Write the PBL RCW in the Code Warrior.
You have to click on PBL1:PBL at the bottom left on the window "'components"' and then in the part of properties in the right you can configure the PBL RCW.
In the window "'validation"" you can write the new configuration to your device.
And if you prefer import a configuration you can read a device too.
Best regards!
3,414件の閲覧回数
yoshida08
We are using LS1043A.
We cannot solve the problem that HRESET does not change to High on our design board.
3,424件の閲覧回数
Pavel_Hernandez
Could you tell me what kind of MCU you are using?
Pavel
