No rule to make target
5,679件の閲覧回数
sufree
I just Run CW MCU v10.6 and  imported a project from another place.After Buid,the following error occurrs:
mingw32-make: *** No rule to make target `/src/S12ZVM_system/startup_CW/S12zvm.prm. needed by explicit-dependencies . stop.
タグ(1)
5,022件の閲覧回数
TICS_Fiona
Thanks a lot for contacting us.
Please click on <Project> menu -> Clean to rebuild the project.  Does the error disappear? If the project contains Processor Expert, please right click on the file "ProcessorExpert.pe" and select "Generate Processor Expert Code", then clean and rebuild the project.
Hope it helps! If not, please attach your project folder, thanks!
Best Regards
Fiona Kuang
TIC - Technical Information Center
Note: If this post answers your question, please click the Mark Correct button. Thank you!
4 返答(返信)
5,022件の閲覧回数
BlackNight
that message is caused because the make file cannot find a file and/or fullfil a rule (see https://mcuoneclipse.com/2012/03/12/no-rule-to-make-target/ ). As Fiona indicated, usually a 'clean' solves that because it recreates the make files.
Can you check if that linker parameter file (/src/S12ZVM_system/startup_CW/S12zvm.prm) exists in your project?
I hope this helps,
Erich
5,022件の閲覧回数
sufree
Thank you for your advice!
5,023件の閲覧回数
TICS_Fiona
Best Regards
Fiona Kuang
5,022件の閲覧回数
sufree
Your suggestion solved my problem perfectly.
Thank you !
