N_Cr_timeout Error
N_Cr_timeout Error
1,615 次查看
chetan_k6379
I want to generate LIN driver code for MC9S12ZVL32F0CLF but when I verify NPF file then I am getting
Description Resource Path Location Type
line: 456 "DG8" - The N_Cr_timeout is a property of LIN 2.1 slave nodes only. LIN2_2019.ldf /LIN_DriverCreation/Sources line 456 Problem
For LDF file there is no issue.
Thank you in advance.
1,494 次查看
dianabatrlova
Hello Chaitanya,
I added some points into your second request N_Cr_timeout Error
I hope it helps.
Diana
