Most recent CW Version for S12XF MCUs?
1,755 次查看
julianrenz
Hi everybody,
I'm getting started with FlexRay development using a S12XF 2-Node Starter Kit. While waiting for the shipment to arrive, I began searching for the best suitable IDE for the projekt. Since the projet is in evaluation phase, there is no budget on a IDE unfortunately. Therefore I searched for a "Special Edition" of CodeWarrior and stumbled upon the Special Edition: CodeWarrior for HCS12(X) Microcontrollers (Classic). After installation I discovered, that the descriptor "Classic" implies, that it is a rather old Version of CW, which is understandable as the S12XF Series isn't that new either.
Considering that, my question is the following: Is there a more recent and free Version (preferrably based on Eclipse) that supports the S12XF MCU Family other than Special Edition: CodeWarrior for HCS12(X) Microcontrollers (Classic)?
Many thanks in advance
Julian
标记 (5)
1,503 次查看
Hi Julian,
So far , the Eclipse can not support S12X mucs.
The latest version is the CWS12V5.1 which you mentioned.
Hope it helps
Alice
1,504 次查看
Hi Julian,
Hope it helps
Alice
1,503 次查看
julianrenz
Hello Alice,
many thanks for the information!
