License file - floating
2,531 次查看
elimakdasi
i generated license file for      CodeWarrior for Microcontrollers - Professional Edition v 6.3. when trying to compile i get the message that the license is for different compiler. this is after rehost.
Original Attachment has been moved to: license.dat.zip
2,317 次查看
elimakdasi
Error   : Unable to use the plugin "CodeWarrior C/C++". It is licensed and a valid license key was not found.
License server system does not support this version of this feature.
Feature:       Win32_ColdFire_Compiler
License path:  C:\Program Files\Freescale\CodeWarrior for Microcontrollers V6.3\license.dat;
FLEXnet Licensing error:-25,147
For further information, refer to the FLEXnet Licensing documentation,
available at "www.macrovision.com".
Installed Products:
 CodeWarrior Development Studio for Microcontrollers V6.3 HCS08 LH64/LL64 Service Pack, build 100212.
 CodeWarrior Development Studio for Microcontrollers V6.3 HCS08 MM128/JE128 Service Pack, build 100728.
 CodeWarrior Development Studio for Microcontrollers V6.3, build 9279.
 CodeWarrior Development Studio for Microcontrollers V6.3.1 Patch, build 10105.
IDE Version: 5.9.0 Build 5292
Plugins: 78
ASINTPPC.dll              5.9.0 Build 5292          5.9.0.5292                5.9.0.5292                27/08/2009, 20:43         628K
CmdIDE.exe                5.9.0 Build 5292          5.9.0.5292                5.9.0.5292                27/08/2009, 20:55         41K
IDE.exe                   5.9.0 Build 5292          5.9.0.5292                5.9.0.5292                27/08/2009, 20:53         10.26M
IDENewDialog.dll          5.9.0 Build 5292          5.9.0.5292                5.9.0.5292                27/08/2009, 20:44         201K
IDE_MFC60cw.dll           6.00.8665.0               6.0.8665.0                6.0.4.0                   27/08/2009, 20:38         1.59M
IDE_MSL_DLL90_x86.dll     5.9.0 Build 5292          5.9.0.5292                5.9.0.5292                27/08/2009, 20:36         296K
InstallHelperKeys.exe     No Version Info           0.0.0.0                   0.0.0.0                   22/03/2005, 18:01         76K
lmgr11.dll                No Version Info           0.0.0.0                   0.0.0.0                   28/05/2008, 16:05         1.42M
lmgr8c.dll                No Version Info           0.0.0.0                   0.0.0.0                   15/02/2004, 18:02         832K
MWCore5_0.dll             5.9.0 Build 5292          5.9.0.5292                5.9.0.5292                27/08/2009, 20:39         240K
MWRADUtils.dll            5.9.0 Build 5292          5.9.0.5292                5.9.0.5292                27/08/2009, 20:44         260K
Mwregsvr.exe              5.9.0 Build 5292          5.9.0.5292                5.9.0.5292                27/08/2009, 20:45         36K
MWRegSvrWinApp.exe        5.9.0 Build 5292          5.9.0.5292                5.9.0.5292                27/08/2009, 20:45         36K
PluginLib.dll             5.9.0 Build 5292          5.9.0.5292                5.9.0.5292                27/08/2009, 20:37         120K
PluginLib2.dll            5.9.0 Build 5292          5.9.0.5292                5.9.0.5292                27/08/2009, 20:37         120K
PluginLib3.dll            5.9.0 Build 5292          5.9.0.5292                5.9.0.5292                27/08/2009, 20:37         120K
PluginLib4.dll            5.9.0 Build 5292          5.9.0.5292                5.9.0.5292                27/08/2009, 20:37         84K
PluginLib5.dll            5.9.0 Build 5292          5.9.0.5292                5.9.0.5292                27/08/2009, 20:37         84K
PluginLib6.dll            5.9.0 Build 5292          5.9.0.5292                5.9.0.5292                27/08/2009, 20:37         84K
SHW32.DLL                                           4.0.1.0                   4.0.1.0                   11/02/2000, 01:15         110K
sunvmhub.dll              No Version Info           0.0.0.0                   0.0.0.0                   29/01/2002, 22:20         49K
tcl84t.dll                8.4.12                    8.4.2.12                  8.4.2.12                  25/09/2006, 21:22         576K
utf8conversion.dll        No Version Info           0.0.0.0                   0.0.0.0                   22/05/2008, 18:36         524K
xerces-2_2_0.dll          2, 2, 0                   2.2.0.0                   2.2.0.0                   27/08/2009, 20:45         2.14M
Bin\plugins\com
 CPPCodeCompletion.dll     5.9.0 Build 5292          5.9.0.5292                5.9.0.5292                27/08/2009, 20:55         808K
 DebugDatabase.dll         5.9.0 Build 5292          5.9.0.5292                5.9.0.5292                27/08/2009, 20:59         324K
 DebugRegisterMgr.dll      5.9.0 Build 5292          5.9.0.5292                5.9.0.5292                27/08/2009, 21:00         116K
 HC(S)08Wizard.dll         5.2.9279                  5.2.0.9279                5.2.0.9279                07/10/2009, 23:30         960K
 MWActivate.dll            5.9.0.5292                5.9.0.5292                5.9.0.5292                27/08/2009, 20:55         572K
 PackAndGo.dll             1,0,0,9279                1.0.0.9279                1.0.0.9279                07/10/2009, 23:31         344K
 PE_options.dll            1, 0, 0, 13               1.0.0.13                  1.0.0.13                  08/08/2005, 12:33         32K
 PE_Plugin.dll             4.34.0.5219               4.34.0.5219               4.34.0.5219               29/09/2009, 13:16         7.50M
 PE_prelink.dll            1, 0, 0, 4                1.0.0.4                   1.0.0.4                   08/08/2005, 12:34         95K
 TipOfTheDay.dll           1,0,0,9279                1.0.0.9279                1.0.0.9279                07/10/2009, 23:30         64K
Bin\plugins
Bin\plugins\compiler
 asm_mcf_elf.dll           6.0 build 1003            5.0.0.1003                5.0.0.1003                07/04/2010, 14:25         290K
 ELFImporter.dll           1.0 Build 0005            1.0.0.5                   1.0.0.5                   07/04/2010, 14:26         39K
 hw_hc08_assembler.dll     5.0.14.9279               5.0.14.9279               5.0.14.9279               07/10/2009, 12:46         87K
 hw_hc08_compiler.dll      5.0.14.9279               5.0.14.9279               5.0.14.9279               07/10/2009, 12:46         87K
 hw_hc08_importer.dll      5.0.14.9279               5.0.14.9279               5.0.14.9279               07/10/2009, 12:46         87K
 hw_rs08_assembler.dll     5.0.14.9279               5.0.14.9279               5.0.14.9279               07/10/2009, 12:46         87K
 hw_rs08_compiler.dll      5.0.14.9279               5.0.14.9279               5.0.14.9279               07/10/2009, 12:46         87K
 hw_rs08_importer.dll      5.0.14.9279               5.0.14.9279               5.0.14.9279               07/10/2009, 12:46         87K
 MCFCCompiler.dll          6.0 build 1003            6.0.0.1003                6.0.0.1003                07/04/2010, 14:24         2.12M
 OsekCompiler.dll          2, 1, 2, 0                2.1.2.0                   2.1.2.0                   12/09/2006, 13:00         75K
 PCLintCompiler.dll        1.5                       1.5.0.5                   1.5.0.5                   04/09/2003, 15:58         80K
Bin\plugins\Editor
 HC08_Coloring             No Version Info           0.0.0.0                   0.0.0.0                   16/04/2007, 16:04         39K
 MWE_Common_Coloring       No Version Info           0.0.0.0                   0.0.0.0                   29/12/2004, 20:23         29K
 RS08_Coloring             No Version Info           0.0.0.0                   0.0.0.0                   16/04/2007, 16:04         78K
Bin\plugins\linker
 BatchRunnerPostLinker.dll 2.0.0 Build 0006          2.0.0.6                   2.0.0.6                   09/07/2004, 13:01         40K
 BatchRunnerPreLinker.dll  1.0.0 build 0002          1.0.0.2                   1.0.0.2                   09/07/2004, 13:01         42K
 CRCPostLinker.dll         2.0 build 0               2.0.0.0                   2.0.0.0                   07/04/2010, 14:26         31K
 ExternalBuildLinker.dll   5.9.0.5292                5.9.0.5292                5.9.0.5292                27/08/2009, 21:03         80K
 hw_hc08_libmaker.dll      5.0.14.9279               5.0.14.9279               5.0.14.9279               07/10/2009, 12:46         92K
 hw_hc08_linker.dll        5.0.14.9279               5.0.14.9279               5.0.14.9279               07/10/2009, 12:46         92K
 hw_rs08_libmaker.dll      5.0.14.9279               5.0.14.9279               5.0.14.9279               07/10/2009, 12:46         92K
 hw_rs08_linker.dll        5.0.14.9279               5.0.14.9279               5.0.14.9279               07/10/2009, 12:46         92K
 MCFLinker.dll             6.0 build 1003            6.0.0.1003                6.0.0.1003                07/04/2010, 14:24         398K
 PCLintLinker.dll          1.5                       1.5.0.5                   1.5.0.5                   04/09/2003, 15:58         84K
Bin\plugins\preference_panel
 hw_hc08_assembler_panel.dll 5.0.14.9279               5.0.14.9279               5.0.14.9279               07/10/2009, 12:46         89K
 hw_hc08_burner_panel.dll  5.0.14.9279               5.0.14.9279               5.0.14.9279               07/10/2009, 12:46         89K
 hw_hc08_compiler_panel.dll 5.0.14.9279               5.0.14.9279               5.0.14.9279               07/10/2009, 12:46         89K
 hw_hc08_importer_panel.dll 5.0.14.9279               5.0.14.9279               5.0.14.9279               07/10/2009, 12:46         89K
 hw_hc08_libmaker_panel.dll 5.0.14.9279               5.0.14.9279               5.0.14.9279               07/10/2009, 12:46         89K
 hw_hc08_linker_panel.dll  5.0.14.9279               5.0.14.9279               5.0.14.9279               07/10/2009, 12:46         89K
 hw_rs08_assembler_panel.dll 5.0.14.9279               5.0.14.9279               5.0.14.9279               07/10/2009, 12:46         89K
 hw_rs08_burner_panel.dll  5.0.14.9279               5.0.14.9279               5.0.14.9279               07/10/2009, 12:46         89K
 hw_rs08_compiler_panel.dll 5.0.14.9279               5.0.14.9279               5.0.14.9279               07/10/2009, 12:46         89K
 hw_rs08_importer_panel.dll 5.0.14.9279               5.0.14.9279               5.0.14.9279               07/10/2009, 12:46         89K
 hw_rs08_libmaker_panel.dll 5.0.14.9279               5.0.14.9279               5.0.14.9279               07/10/2009, 12:46         89K
 hw_rs08_linker_panel.dll  5.0.14.9279               5.0.14.9279               5.0.14.9279               07/10/2009, 12:46         89K
 OsekPanel.dll             2, 1, 2, 0                2.1.2.0                   2.1.2.0                   29/08/2006, 17:11         70K
 PAssemblerCF.dll          5, 0, 0, 1                5.0.0.1                   5.0.0.1                   07/04/2010, 14:26         198K
 PBackEndCF.dll            6.0 build 1003            6.0.0.1003                6.0.0.1003                07/04/2010, 14:26         77K
 PBatchRunnerPostLinker.dll 2.0.0 Build 0004          2.0.0.4                   2.0.0.4                   11/09/2003, 22:31         39K
 PBatchRunnerPreLinker.dll 1.0.0 build 0003          1.0.0.3                   1.0.0.3                   11/09/2003, 22:31         29K
 PCFGlobalOptimizer.dll    6.0.0.1003                3.0.3.1003                3.0.3.1003                07/04/2010, 14:26         33K
 PCLintOptions.dll         1.5                       1.5.0.5                   1.5.0.5                   04/09/2003, 15:58         41K
 PCLintSettings.dll        1.5                       1.5.0.5                   1.5.0.5                   04/09/2003, 15:58         82K
 PCRCPostLinker.dll        2.0.0 Build 0             2.0.0.0                   2.0.0.0                   07/04/2010, 14:26         45K
 PDebugx86Except.dll       5.9 Build 5292            5.8.0.0                   5.8.0.0                   27/08/2009, 21:04         64K
 PDisassemblerELF.dll      1.2.0 Build 4             1.2.0.4                   1.2.0.4                   07/04/2010, 14:26         45K
 PExternalBuild.dll        1.0.1.0                   1.0.1.0                   1.0.1.0                   27/08/2009, 21:03         64K
 PFrontEndC.dll            5.9 Engineering Build     5.8.0.0                   5.8.0.0                   07/04/2010, 14:26         68K
 PLib.dll                  5.9 Engineering Build     5.8.0.0                   5.8.0.0                   07/04/2010, 14:26         225K
 PLinkerCF.dll             6.0 build 1003            6.0.0.1003                6.0.0.1003                07/04/2010, 14:26         49K
 pMWCVS.dll                1.3.0.5292                1.3.0.5292                1.3.0.5292                27/08/2009, 21:03         64K
 pmwSourceSafe.dll         5.5.1.40704               5.5.1.40704               5.5.1.40704               13/04/2004, 16:47         29K
 PPreprocessorC.dll        5.9 Engineering Build     5.8.0.0                   5.8.0.0                   07/04/2010, 14:26         72K
 PProjectCF.dll            6.0 build 1003            6.0.0.1003                6.0.0.1003                07/04/2010, 14:26         30K
 PWarningC.dll             5.9 Engineering Build     5.8.0.0                   5.8.0.0                   07/04/2010, 14:26         68K
Bin\plugins\Support
 CPlusSourceGen.dll        5.9.0 Build 5292          5.9.0.5292                5.9.0.5292                27/08/2009, 20:53         272K
 crcgen.exe                No Version Info           0.0.0.0                   0.0.0.0                   07/04/2010, 14:26         140K
 MWComBase.dll             5.9.0 Build 5292          5.9.0.5292                5.9.0.5292                27/08/2009, 20:42         64K
 MWComHelpers.DLL          5.9.0 Build 5292          5.9.0.5292                5.9.0.5292                27/08/2009, 20:40         460K
 MWRadModel.dll            5.9.0 Build 5292          5.9.0.5292                5.9.0.5292                27/08/2009, 20:44         572K
Bin\plugins\version_control
 mwcvs.dll                 1.3.0.5292                1.3.0.5292                1.3.0.5292                27/08/2009, 21:03         228K
 mwSourceSafe.dll          1.0.3.716                 1.0.3.716                 1.0.3.716                 13/04/2004, 16:47         137K
 VCSClearCase.dll          1.1.2.1999                1.1.2.1999                1.1.2.1999                29/09/2004, 16:28         76K
Bin\resource
 CPlusResources.dll        5.9.0 Build 5292          5.9.0.5292                5.9.0.5292                27/08/2009, 20:53         24K
 ExternalBuildResources.dll 5.9.0 Build 5292          5.9.0.5292                5.9.0.5292                27/08/2009, 21:03         6K
 IDEAuxiliaryResources.dll 5.9.0 Build 5292          5.9.0.5292                5.9.0.5292                27/08/2009, 20:40         44K
 IDEResources.dll          5.9.0 Build 5292          5.9.0.5292                5.9.0.5292                27/08/2009, 20:40         52K
2,317 次查看
ZhangJennie
Hi Eil,
from your license content, your license is professional version license:
"#CodeWarrior Development Suite - Professional Edition, Perpetual Model,
#Floating License - CodeWarrior for Microcontrollers - Professional Edition
thus your license should support full function c++ feature.
if this feature can not work, I suggest you contact NXP license support team by creating a ticket.
Here is how to
https://community.nxp.com/docs/DOC-329745
Jennie Zhang
2,317 次查看
ZhangJennie
Hi Eli,
So solve your problem, please provide us more information:
1. your CW version:
  - if you use classic version: Start the IDE and click on Help | About Freescale CodeWarrior. Click on Installed Products.Save all info displayed into a txt file and send it to me.
2.  error screenshot.
Thanks for your cooperation!
Jennie Zhang
