How to save environment variables in CW
3,414 次查看
xuedongyang
I am using CW to build the executable of VSPA. To build, I need to use an environment variable called "L1REALTIME". Usually before I build, I highligh the project, right click, and select "properties". Then in the Properties window, I add the new environment variable. Click "Apply" and then "OK" to close the Properties window.
However, if I close the CW, and then bring it up again, I observed that the added environment variable "L1REALTIME" is not there any more. I need to repeat the above procedure to add it again.
My question is: Is there anyway that I can add the new environment variable only one time and save it, so that next time I bring up CW, I don't need to add it again?
Thanks.
3,393 次查看
EdwinHz
I recommend you look into this post by Erich Styger. I believe you will find it useful for your inquiry:
https://mcuoneclipse.com/2013/12/22/eclipse-build-variables/
Edwin.
3,394 次查看
EdwinHz
Edwin.
