How to import an existing CW project into subversion using subversive plugin?
1,715 次查看
richardunruh
I'm running CW 10.6. I have installed the Subversive plugins from the Subversive-1.0.0.I20130122-1700.zip archive and added the Polarion SVN connectors, then added the repository location. Everything seems happy, but I can't for the life of me figure out how to import my existing CW project into subversion using the subversive plugin. Can someone point me in the right direction?? Even if it's "RTFM" and a page number.
Thanks.
1,543 次查看
Hello Richard,
- There is a User guide about using SVN on KDS, while I think it is the same with CW10.6:
Getting started with SVN and Kinetis Design Studio
For you have install SVN , so you only needcheck the part of "4. Using version control" .
- There also a Lab about using vesrsion control on CW:
Subversion (SVN) Codewarrior 10
Alice Yang
