How to disable optimization for protecting an unused function
2,586 次查看
jasoncui
I created a function, and didn't call it in my project, the compiler treated it as unused dead code and removed it by the linker. I hope the optimization doesn't work only for this function, how can I do? The CodeWarrior I used is ver5.9, and the MCU is MC9S12G128.
Any help would be much appreciate!
2,399 次查看
ZhangJennie
Hi Jason.
add the function name to ENTRIES block in prm file can avoid unused function being optimized. can you please try it? can it work for you?
Jennie Zhang
2,399 次查看
jasoncui
Hi, Jennie
I works well. Thanks a lot.
2,399 次查看
ZhangJennie
you are welcome!
Jennie Zhang
