How to Avoid PE to Ruin Your Code during Coding?
已解决
跳至解决方案
2,281 次查看
luchaolong
What's the best way to avoid activating Processor Expert to update the code during Project build? especially during the 'Build All'?
The manual 'Build Project' will not active the PE to regenerate the code, but just in case if anyone would click the 'Build All' thus all the user's code will be ruined.
Leo
标签 (1)
标记 (1)
1 解答
2,157 次查看
BlackNight
you can disable code generation by component and as a project settings, see Disable my Code Generation | MCU on Eclipse
I hope this helps,
Erich
在原帖中查看解决方案
1 回复
2,158 次查看
BlackNight
I hope this helps,
Erich
