How can I define the order of module initilations with PE?
1,632 次查看
mikijt
Hi  :
in CW the order of module initilations seem to be constant,how can i change it?
MiKi
2 回复数
1,576 次查看
FelipeGarcia
Hi MiKi,
You can change the order in the Initialization Sequence view. To open this view, click Window > Show View > Other... and select ProcessorExpert > Initialization Sequence.
I hope this helps.
Felipe
1,576 次查看
mikijt
Thank you very much
